Jackhill442
- Atlanta
I just installed a new steering gear from PSC, a company I heard was really good. Problem: The gear binds on center. It steers well at speed, but sticks on center. Adjusting the top screw doesn't have much effect, I tried several loosenings of it, nothing. Then, I shortened the drag link, and the binding still occured "on center" though the box was nowhere near on center, so I don't think it is the over center adjustment. Is it the worm bearing preload being too tight? Or is it just a new gear that needs time to break in? If it is the worm bearing preload, how do you adjust. This thing has a funky collar at the input shaft. Do you turn that to loosen, then loosen the inner ring? Help! I don't want to have to swap it out and send it back.
