I should be more spucific I am looking for the stater plat or pick up that is in the distributorused to puls the injecters on the rite stroke it has two positions it can be in I would like to know witch one
thanks
The black plastic pickup in the bottom of the distributor is sitting at the 4 O,clock position looking down and using the wires going in as 12:00 O,clock. The rotating part on top has two scew holes, but two different size raised oval tits, so the rotoating wheel goes on only one way.
There is only one raised screw hole (in my distributor an 87) in the bottom of the distributor and a small metal bar from the screw hole to the right raised pin (looking down), on the pick up assembly.
The center of the black pickup is almost exactly halfway between 3 and 6 in the firing order, on the distributor cap.
Make any sense? Sorry I took so long had to go look.
