- Yucaipa, CA
89 XJ Limited 2Dr
275K miles
4.0 Liter
Automatic
NP242
The Awesome…
Slip Yoke Eliminator
Dana 30 Front, Lockout Hub Conversion, crossover heim steering and track bar, trussed, 4.88 gears, Detroit Locker, Warn Cro-Moly axle shafts (inner and outer) CTM 300M u-joints
GM 12 Bolt rear, 4.88 gears, Detroit Locker, Alloy USA Axles
Rubicon Express Long Arms, Rubicon 4.5” springs, Clayton crossmember
Prothane floating bump stops
Rubicon Express Leaf packs, 3.5”
Super high clearance tube bumpers front and rear
PRP Daily Driver seats
Heavy Duty low-profile Rock Sliders
Heavy duty steel tail light boxes
TJ Flares all around
35x12.50/17 Kenda Klever M/T tires, maybe 2000 miles on them
HID headlights
Two 4” HID off road lights
K&N air filter
Magnaflow muffler
Aluminum pressure tank for the radiator
A/C blows cold, heater blows hot
The not so awesome….
The jeep runs well, a little tired, but still passes smog
Power steering pump leaks a little and whines some when the fluid gets hot
Slip on front drive shaft is a bit worn
Driver’s side quarter glass was replaced with a piece of lexan, I have a pair of one piece quarter glass you can have.
Windshield has a crack in it
Dash has a crack in it
Has noisy window regulators
Cheap stereo
All that being said, it has been very reliable, and never left me stranded, and I’ve driven it to Baja numerous times. Body is in pretty decent shape. Especially for it being 27 years old
$4500 obo 909-855-1017
275K miles
4.0 Liter
Automatic
NP242
The Awesome…
HID headlights
K&N air filter
Magnaflow muffler
Cheap stereo
