sandblaster87
- Sparks, NV
Runs good, and drives good. Clean nv title. Has pretty much brand new 30" tires. just did a tune up, new plugs, cap, rotor, wires, oil and fuel filters, air filter, water pump, thermostat, radiator, idler pulley and serpentine belt, coolant bottle. Also took the clutch fan off and replaced it with an electric fan off a '98 xj, both efans are wired to a switch. Doesn't over heat at all! I also have all four stock power doors that match the jeep, it has manual power doors on it now. Needs some work...The transmission just lost reverse (but I have a replacement trans for it, just needs to be installed) needs a battery, radio needs to be hooked up and the linkage needs to be adjusted for the 4wd.
4.0 motor, Dana 30 and 35 axles, with 3.55 gears, aw4 trans and 231 tcase
asking $650 on CL but if someone on here wants it I'll go $550.
