badgator
- Roaming the swamps
My 89 AW4 sounds like it's grinding gears, under light throttle, it will literally pop out of gear (for a couple seconds) into neutral, grind / ratcheting sound, back into gear.
Fluid is clean, TV adjusted, TPS adjusted, 242 transfer case in 2wd.
Definitely not the trans mount.
Has happened 5-6 times in the last month I don't drive it much, 45-50 mph .
Tell me what you think.
