rpyne
- Provo, Utah
I am at my whits end. I have an 88 Cherokee I-6 that won't start when the engine is warm. It starts fine when it is dead cold. I have noticed that just about the temperature when the thermostat opens it will either cut out for a second or two if I am above idle, or die if at idle, then it won't start until it cools down. It cranks fine, just won't start.
In the last couple months I have replaced the Coolant Temperature Sensor, the Cam Position Sensor (in the distributor), the Crank Position Sensor, the Ignition Module and the Engine Control Unit (Computer).
ANY help on where to look now will be greatly appreciated.
