'88 Xj: Need IAC Motor O-ring Dimensions
RAVC1
Michigan
To the best of my knowledge you get the o-ring when you purchase a new IAC motor. My motor is fine and I just cleaned it and the complete throttle body. I prefer to replace the o-ring but it may also be a proprietary size. Does anyone here know the dimensions of this o-ring?
Have you measured it, everything I've used so far has been a standard size you can p/u at Ace!
Glad you responded. No, I did not measure it yet. I will but I did not want to trust my measurements. I plan to take the throttle body, the IAC and the current o-ring to the hardware store shortly.
I called Standard Motor Products (AC12) but they do not have the dimensions.
