shelbyluvv
- 29 Palms, CA
I just got my new to me 88 XJ delivered and the owner lost the ignition key. Great! It was dropped right in the middle of my driveway blocking both my garage doors. Not good. Mama wants to go shopping and the POS XJ is blocking the Dragon' Wagon in the garage. Time to get busy and NOW!
For starters remove your horn cover, and steering wheel nut. Then put your steering wheel/pulley puller in place and remove the steering wheel.
Push the black cam lock cover down and shove a screw driver in to hold it down. This is so you can get to the snap ring at the bottom of the steering wheel mount.
Use a sharp small screw driver to get the snap ring moved into a easy to get to position.
Once in position, use another screwdriver with a small blade to, gently pry the snap ring up while keeping it from spinning with the second screwdriver. Watch the threads on the steering column they are sharp! Ask me how I know.
After you get the snap ring out of it's groove pull it off and set it someplace you will not lose it.
BE CAREFUL HERE!
The cover in under pressure. Not a lot but better safe than sorry.
Apply steady FIRM pressure to the cam lock cover and remove the screwdriver and slowly release the pressure from the spring below it.
Now you can remove the cover and see the turn signal cams.
Remove the center and the spring below it and set them in a safe place as well.
Remove the screw holding the turn signal arm in place and put the screw and lock place with your other parts.
Here you can see the three screws that hold the turn signal can in place. Remove these screws and keep them seperate. They are a special thread.
Remove the Hazard pull knob.
Disconnect the plug on the lower right side of the steering column. It is right above the brake pedal.
With these two parts removed you can now pull the cam up and over the steering wheel mount threads.
Here is the bolt that holds the ignition lock in place. Use a 5/16 socket and remove it.
BE CAREFUL HERE!
