'88 MJ, stroker, long arms, 35"s $6500 OBO
rredalty
Lenoir City, TN
Life has been taking me different directions for a while and taking more and more time from wheeling and being able to enjoy the Jeep for what it is. Need to sell and move on. Still got Tiffs to wheel when the time is there but that isn't too often right now and it looks to get worse. I would hate to see this thing sit in the yard and rot.
1988 Jeep Comanche Pioneer model.
-4.6 stroker with maybe 4K mi. Renix block, 94 head portmatched, 99+ intake manifold. Oil changed regularly using Mobil 1 syn.
Still running on Renix system. Motor runs beautifully and pulls like crazy.
-Borla header
-Rustys intake
-62mm Throttle body
-24lb injectors
-Flowmaster 40 series muffler
-M.O.R.E. motor mounts
- AW4 swappen in using all factory wireing. Fresh filter and fluid change. Shifts smooth. BIG tranny cooler.
-NP231 Crown SYE, big chain and sprokets.
-35x12.5x15 Goodyear MTR's with Kevlar, Bought new 4 months ago.
-15x8 soft 8's
-D30 front axle
-trussed and gusseted knuckles
-4.88's
-Aussie locker
-297 shafts with new 760 joints
-Superior tube seals
-Rugged Ridge HD steering with sapre tie rod and BDS stabilizer
-RE swaybar disconnects
-Solid diff cover
-2 sets of 260 joint spare shafts
-Ford 8.8 rear
-4.88's
-Lockrite locker
-Rockstomper diff cover
-Rock Krawler front long arms
-Rubicon Express HD trac bar, bracket and brace
-Rubicon Express 4.5" coils with 1.5" poly spacer
-Rubicon Express stainless braided front brake lines
-Rancho RS9000 front shocks
-Rear SOA with new Rough Country white shocks
-Dual duaphram brake booster and new master cylinder
-HD rear traction bar
-York 210 OBA system
-PSC steering pump and reservoir
-Derale steering cooler
-Hella E-Code housings with HID's
-Rugged Ridge 7" HID's mounted on front bumper
-MFX front bumper with recessed winch mount
-Warn M8000 winch
-Masterpull 3/8" x 100' rope
-Stainless hood vents
-Appalachain Armor t-case skid
-Bed bobbed 8"
-1.5"x4" rocker replacement and 1/4" boatsides from frame rails to rockers
-1.5"x.134" cage using 8 mounting points(6 points in cab) all directly linked to the frame.
-Recovered factory MJ buckets using alligator inserts.
-New RCI 4 point 3" latch harnesses mounted to cage
-Optima Red Top battery
-All b+ and gnd cables raplaced using 2ga wire and brass terminals.
There is more I have forgotten but this will do for now. This Jeep will flat out get it. I have been surprised how well it has performed at everything I have asked it to do. This is a true multi-purpose rig if you are looking for something to daily drive or keep on the trailer. It will run 85+ down the interstate all day and never touch 211 degrees.
I am not interested in parting out and I'm not looking for any trades. Located in Knoxville, TN and I can deliver for cost of fuel. Asking $6500 and I'm pretty firm on that. I do have a clean title for this Jeep and for thise interested, Tiff has made this decision with me, she is NOT included in sale.
