87 Cherokee 4x4.
jeeptec
87 CHEROKEE 4x4 .4.0 aw4 automatic. 212k on odo. Both engine and trans have been replace with reman units by previous owner.6.5 teraflex long arm lift using rustys springs. Otk high steer . Track bar and steering box brace.93 non disconnect axle using all 93 axle shafts hub bearings and front brakes. braided brake lines .rear Dana 44. Ected electric locker Tera flex rear disc brakes .4.56 gears .brake booster and master is a 95/96.. advance adapters HD slip yoke eliminator kit and double Cardin rear drive line.. custom sliders .custom front bumper able to bolt on a winch. Custom rear bumper. Has mounting nuts for high lift jack. HD. Aluminum radiator converted to 91 style. Has 97 aux fan. Oil filter adapter has been changed to standard thread oil filter (91 style). Larger throttle body and spacer. Precision fuel injectors. Good interior. Tan hounds tooth. Drivers seat is torn. Only seat that is torn.body color is beige ( a dull yellow) body has some 4x4 damage but other wise decent shape.head lights are wired relay for more output. Has wide brute 31/10.50/15 tires on eagle alloy rims. Jeep is lifted and geared for either 33 or 35 inch tires. Not included.. there maybe more up grades that I have missed. Registered and smogged. Asking 3750.00 obo. Pvt me
