mtnbiker326
- Albuquerque, NM
Here is the issue. I have just removed the old SMASHED Ac controls (break in for CD player) and have noticed that the number 1 and number 9 hoses out of the vacuum lines to the controls are cut and screws have been inserted with heat sealing rubber covers over them. What is the significance of these two hoses? I don't have Heat nor AC. The blower works fine and so does the core (so I think). I believe that the valve between the ac and heater is destroyed (going to replace asap). Also I can't get the jeep AIR to run cabin only (don't know if it does). Just really cold in 29 degree weather with outside air coming into the cabin without fan on at all. Any suggestions?
