8.25 used 27 splines in the Cherokee up to '96, which was a running change year. According to ARB, '97 and later have the 29 spline axles. I have a '96 (DOB 10/95), and it had the 27 spline.
Only way to know for sure is to pull the cover and count.....
FYI, I bought new axle shafts from Randy's Ring and Pinion for less than I priced the junkyard replacements. 27 vs 29 are direct replacements, except for the spider gears (I wanted an Air Locker, so that is why I changed). Might as well replace the seals and maybe wheel bearings while you have it apart, cheap insurance for later down the road.
HTH, Cheropair
