LaredoBucket
- Long Beach, California
Hey all,
My Pinion bearings in my 97 29 spline 3.07 gear 8.25 rear went belly up. I found a 98 29 spline 3.55 gear 8.25 rear end at the junk yard, it was missing the axles and the spider gears and shims fell out. Can I use my existing axles & carrier in the new rear end, if i swap the ring gears to use in the new axle?? Is this an easy fix??
my XJ is a 92, 5 speed 2WD with 97 8.25 rear end 3.07 gears, 4.5" lift, running 32 BFGs
