Sure sounds like it to me. I think that is about as good as it gets.
I will reiterate the suggestion to get new U-bolts. When I removed my first axle one of the U-bolts broke before the nut would start to move. Also note that new U-bolts will probably not come in the exact length you need. Too short won't work at all, so you will probably end up with something that is too long. Plan to cut off the excess. Also note that you will want to re-torque the U-bolts after the first hundred miles.
Another potentially useful tidbit: One way or another you are going to be disconnecting the e-brake cables. I have found that the simplest way to get all three tabs on the cable housing compressed at one time is to use a short (like 1") piece of 1/2" copper tubing cut with a roll cutter. The ID of the copper tubing is a bit too big, and the ID as cut with the roll cutter will probably be too small, but with some judicious deburring you should be able to get it just right. That sure beats trying to work your way around the perimeter trying to get one tab at a time through the hole in the backing plate or bracket.
Oh, and one other maybe useful tip: An old lawnmower makes a reasonable axle dolly: http://www.naxja.org/forum/showthread.php?t=1143659
Going to use a jack. with a ratchet strap to hold it.
as for the E brake cables.
Im not using the junkyard e brake cables attached. mainly cos I damaged them. after i got annoyed removing them. I tried to cut through them.
didnt go well
I am going to remove the e-brake lines inside the brake shoes.
then attach mine to the new axle.
I bought rough countries extended brake lines.
they are nice quality.
My main quandary right now is that I want that red ARB cover
but its $200
