shortxjdoug
- Chattanooga tn
listen guys..... its not about how big your willy is its how you use it
listen guys..... its not about how big your willy is its how you use it![]()
no one here is getting upset... this is good typical naxja conversing
and as a thought of keeping the essence the same you could always replace the flat head with a newer 2.5L 4 banger and gear everything super high to compensate.
i believe jp mag did an article on gearing verses engine mods with the 4 cyl ... turns out your get more hp out of gears than engine mods for the same money when it comes to the 4 banger... i digress
i would say go with another 4 banger or the buick v6 that is really short... personally i would do the 4 banger from a 90's wrangler and do a better tranny and a 4:1 transfer case with 5.38's in the axles (axles are up to you) and then you would be able to get a more reliable engine but still be able to push it up a hill on some rocks.
Well ideally I'm going to build this thing so nothing goes wrong...but fat chance of that happening!
I may have to just grin and bear it and deal with the I4 and the T90 for now, then aquire parts and what I need for a complete rebuild.
Tossing around the idea of sourcing a motor with air conditioning, I think the possibility of having a jeep with onboard air is a good idea. And it's cheaper than that Warn winch that has the compressor on it, even though I really like it and want one!
Also would like to run 110 amp alt and a dual battery setup.
Question. What's the legality issues of having a fuel cell in the rear seat area. I've said that the back seat is coming out and that's where the fuel cell (and probably an air tank) will be going. Along with some sort of tool box...maybe a few ammo cans.
BTW, being 2000 miles away from the jeeps is hard when planning something like this.
