66 deuce and a half
Swamprat
little Tijuana
posting for a friend of mine.
http://forums.nasioc.com/forums/showthread.php?t=2308434
Ok so I have a 66 deuce and a half I have never driven it
I bought it three years ago and it still sits where I bought it
the owner sold it to me and said it just quit running
so after buying it I worked on it for a wile it would run but it was rough!
I eventually took the oil pan off and discovered its crank shaft is broke into two pices!
I located the parts and never installed them
I have a used bottem end for it it was just rebuild and had a clogged injector and burned a hole in the piston
so you could make a good engine out of two
so here is the good stuff
It had all new tires put on it 150 miles prior to breaking its crank shaft
magnaflow exhaust
steel flatbed
line-x inside the whole cab
it is a multi fuel... ie oil, used oil, gas, kerosene, ect...
the owner had spent over 9k on it by the time he sold it to me
it has set in the same place for three years and I know one tire is flat but I have two new ones mounted and ready to go on
it will either new batteries or see if it will take a charge
it is located just outside of wolf city texas
im asking 2000.00 because I can get that on the scale at the scrap yard it weighs in at just over 14k
I have a clean open title in hand
