Rockken
NAXJA Member # 1674
- Westminster, Co.
I'm installing tail lights on the back of my rig and have come to the conclusion that I need a couple 6 ohm 50 watt load resistors to get everything working correctly. These are the same resistors you may need when installing LED tail lights. They emulate a bulb and keep the blinkers working correctly. Unfortunately I cannot find these resistors locally, I've tried checker, car quest and radio shack, anybody know of a store in Denver that might carry these? I know what you are thinking, why does he need these? I'm installing a single light on each side and need to combine the brake and blinker function. To do this I'm wiring in a trailer tail light converter. However, the tail light converter will not work unless the original light bulbs are present.
Thanks
Thanks
