6.0 LS Swap
[/URL]
How close is the fan to the pulley?
Jeremy,
You are doing everythign right! I wish I would have stayed with the truck intake and brackets. That swap has taken so much time!
Very clean work!
I'm interested in your exhaust--is it aluminized, 304 or 409?
Jeremy,
Very clean work!
Its just aluminized bends and straight pipes I picked up from Summit.
I can't imagine how that radiator is going to dump enough heat, but I suppose Novak has done this before. It makes me want to try keeping the stock XJ rad with three high flow fans.
It has more surface area than the Novak rad and holds 2 gallons of coolant by it self. I will modify the bumper to allow airflow to the lower portion of the rad. It will work just fine. Just testing here at the house in 75 degree weather I can barley get the fan to come on and when it does it comes on for about 5 sec and its back down to 190. I would not try the stock, nowhere near big enough.
I think Frank Z tried the stock for a while, temps were constantly creeping & would get to 240 in short order on the throttle in sand.
Yeah, I wasn't sure if it was you, Frank or the guy who put a 5.3, Stak 300 & a Klune under his rig. One of the first LS swaps on Naxja, anyhow. Am I right in that the stock radiator just wasn't up to it?
Well, today was the test drive.......
Holy $@@!
Wow. Wow. Wow! Unbelievable. I can't express what it felt like. Smoke the tires on demand kind of power. No leaks or overheating. Now to finish the hood. I will post a video and pictures as soon as I can.
:thumbup:
So, where did you get thus radiator? Sorry if you've already stated, but I couldn't find where you'd said.
Fantastic! Can I also bother you for the fan you used? It looks like you're onto a good solution for a lot less than the Novak or FFDynamics options.
I can look it up when I get home, but it also was from Summit. You can search Summits site for a 16" 3.5" deep and I think it was 2850 cfm. The radiator is $170 and the fan was $89. Way way cheaper than the Novak. I tested it out pretty good yesterday and today, highway speeds it doesn't get past 190 and in town the fan comes on for 5 to 10 seconds.
