4cyl. to 6cyl. swap in an MJ
natep1
Rochester, MI
Thinking about a new winter project and I stumbled across a nice deal on a 2wd 1990 MJ w/a blown 4 pooper.
What I wanted to know are what chassis modifications are needed to bolt in 4.0 block?
All I can think of would be the motor mounts & a tranny crossmember (putting in a 904).
Anything else that would need to be done just to get the block to fit?Thanks for any advice.
Nathan
(No luck on the search)
The 90 MJ shouldn't have a lot of trouble taking the 4.0 block - if you were trying to do this with an 86, you'd be in trouble!
You'll want the engine, transmission, and (maybe) the transmission crossmember - I'm not sure if they're the same. Have you done any searching around here? I'm pretty sure this has been covered before. It sounds familiar, anyhow...
5-90
I didn't have any luck finding the chassis info when I searched, maybe I used the wrong terms (who knows?).
I pretty much have everything (besides odds & ends) that I would need to do the swap.
2k based (soon to be) 4.7 stroker, all accesories & electronics for the engine, complete 2k XJ wiring harness, computer & radiator. All I need on the electrical end is a gauge cluster.
I will be using a fresh 904 (5-6k) because I already have it, it can be built up very easily and without too much expense. I may switch to an AW4 in the future but no immeadiate plans.
Fabrication wise, I am hoping it will be as "simple" as installing 4.0 mounts and making a crossmember.
Thanks for the info.
Nathan
I'm doing something remotely similar, We are changing a 4 cyl 2wd to a 4.0 4wd.
It's an 87 do you think a 4l will fit in it? I've searched too but didn't see anything on it.
Yes. The front clip for the XJ/MJ was redsigned for the 1987 MY to accommodate the long inline six block.
If you were working with 84-86XJ or 86MJ, you'd have to do a LOT of work to the front clip. However, most of the work is now done for you.
Don't forget to get all the donor stuff when you get the engine - electronics, wiring, and stuff like that. It will save you trouble. I'd also try to grab exhaust at least back to the catalytic converter - even if it's useless, you can still use it for a pattern.
5-90
Direct swap if the chassis is '87 or newer. The 4.0L uses different motor mounts, but they go to the same place on the chassis. The crossmember is also the same, but you'll need the correct tranny mount for the 4.0L tranny you'll be using.
The 4.0L is a heavier engine, so if you're going to be running at stock height you should use springs from a 4.0L XJ or MJ. If you're lifting, you'll be changing the coils anyway so that'll be a non-issue.
CheapXJ did this swap a couple of years ago. He worked like an unemployed Frito bandito and got the entire swap done in something like 72 hours. I thought he had a write-up on it, but I've been mistaken before.
It brings a tear to my eye when I hear of an MJ being given a new lease on life. :D
Jeep on!
--Pete
ComancheClub.com
Jeep on!
--Pete
ComancheClub.com
I wish you lived closer to Connecticut. I need someone to help convince my wife that these MJs I have here aren't "basura" (Spanish for "trash").
good to see another MJ come back from the dead. The 904 for the stock 4 cyl will not bolt up to the 4.0 if that is your intention, you sill need an aw4 to hook it all up
If I had property and a little bit of money, I'd have quite a collection too. Heck, I'd probably work-over the junkyard to get my hands on the decent bodies that come through. I don't know the specific conditions of yours, are they sitting in the weeds, on blocks, pavement or what? Maybe if they were all in a neat row and looked like a museum collection? :D
Jeep on!
--Pete
ComancheClub.com
Jeep on!
--Pete
ComancheClub.com
Im down to 2 MJ's and 4 XJ's in the yard.....Im doing good
I luckily have one from a 6cyl. Concord. It mocks up nicely.
