I spent all day at the junkyard on Wednesday, and got the following for $220:
'93 Cylinder Head, Intake Manifold, Throttle Body, Fuel Rail, & Injectors
'93 Computer & Wiring Harness (took me forever to figure out how to disconnect it from the fuse block at the firewall
I pretty much took all the sensors at the end of the wiring harness just in case my electric plugs don't match up with the new one, I won't have to splice a bunch of wires.
Power Steering pump, reservoir, & gear box (mine didn't have ps)
A/C Compressor & engine brackets
'93 coolant overflow tank & brackets
Gray interior pieces (it's currently burgandy interior and I hate it)
RE 1600 Track Bar
RE front coil springs
Dakota Rear Springs
Swaybar Disconnects
Braided steel rear brake line
RE lower control arms (RE joint one end, rubber the other end)
Extended front bumpstops
New fender, flare, & inner fender
There might be more, I can't remember
Here are my plans:
Have a local machine shop rebuild & port the new head for better torque & gas mileage ($210 is what he quoted me)
Rip out the burgandy dash and get a gray one, while replacing all the interior wiring with that of a '93 vintage also. Nothing works, so it all needs to be fixed anyways (not working: turn signals, dome light, dash lights, heater controls, radio, windshield wipers, etc. Somebody hacked it all up in the past)
Replace the AX-4 with an NV3550
Convert to 4wd (I'll get the 231 when I get the 3550)
Replace the worn out bench seat with buckets
Replace the rubber floor with gray carpet
Figure out how to add cruise control
and probably much more I'm not thinking of at the moment.
I did buy it as a work truck for the sign installation business I started, installing posts for Real Estate listings, so all I do is carry around signs & sign posts, nothing too heavy. Sorry to be long-winded, comments or suggestions are welcome.
