4-15" inner air locks beadlocks
ipkyss
Hampden, MA
Website says they are good for 15x7-15x10. Work awesome. I was running pitbulls at 1-2 psi with no issue. They do not leak. All look good. No issues with any of the valves. And they use Goodyear tubes, so you can get them from any tire shop. $325 Located in Hampden,ma Sean 413 315 1502
Does the tire size matter?
Unless you were talking a stock size tire, I can see why there would be an issue. I would say a smaller tire might make it a little harder to put them in.
I cant see any reason why there would be any balance issues. I cant provide a great review. I only used them for a few week. But i had no issues with 37 pitbulls at 2 psi.
Not asking for a review. I'm interested in them but I'm running 33s. I just wondered if they would fit inside the 33" circle. At least post a brand name so I can do some research.
The brand name is Inner Air Locks Beadlocks. These may be difficult to put into a 33, but its probably been done. As long as the rim size is right, it will hold any size tire onto that rim. I have Staun beadlocks, and they are not easy to put into my 37's.
Website-- http://innerairlock.com
A.
From what I can tell. They should work down to a 30-31" tire. The smaller the tire, the harder they will be to get in. They are a PITA for sure to set up. But they work good. Double beadlocks, and cheap.
