Hi Guys;
I am 100% sure that the 4.0 is the same for the 2wd and the 4wd but just want to reconfirm. I am swapping my 88 4.0 with a 99 4.0 which is a 2WD. Please let me know.
Hi Guys;
The basic engine is the same, but the ignition and injection are completely different. In addition to needing the ECU for the new engine, you will also need a wiring harness and a fuel pump because they operate at different pressures.
Or you can swap your '88 ignition and injection onto the new engine
Thanks for your reply, can you please amplify on this in particular the injection, also can i used my 88 renix ignition. I was under the impression that only the Tranny and the TC difference make it a 4x4. :dunno:
EDIT;
Eagle i am doing a complete swap that is i am putting the 99 motor with its computer, wiring and the fuel tank. did you maen this ignition and injection were different from the renix, if that is so then i know that, i guess what i meant to ask is the difference between a 99 4.0 4wd and a 99 4.0 2wd.
