FUNKYTEE5
- Vancouver, Wa.
Bloose said:Though there is no question I would prefer a cast iron pump, aluminum pumps are fairly common for OEM applications. I'm sure it's because of lower machining time, and longer tool life when machining. The way a oil pump is built the majority of wear should be between the steel cover plate and the steel gears. There should be plenty of clearance between the aluminum housing and the pump gears. Unless you pick up a fairly large chunk of crap (which should be screened out by the pick up screen) aluminum should be fine and shouldn't wear any faster than an Iron pump.
B-loose
I agree! But my pump that I replaced was chewed up pretty good. That wear could have been a result of the previous owner's habits? I keep my oil clean
Funkytee
