Legacy
- Albuquerque
Does any on make a proformance Intake Manifold for the 4.0 HO?
Thanks for any input, Legacy.
Mike@Accurate said:You (and the late(st) manifold don't have a PCV valve, the tube from the rear of the valve cover is an "orifice tube" and it's flow is calculated in the idle air circuit. Get one from the donor, or don't shorten yours from the VC end.
MN-Cherokee said:Ok, I already know that the fuel rail fits. Do the stock '97 injectors fit the manifold??
Brian
