4.0 help in a '00 WJ?
SeansXJ
2000 Grand Cherokee Laredo
2wd
4.0
Been having problems starting like the battery is low then once it starts it will die right away unless I keep my foot on it. the charge is 14v and it has a 3/4 full tank of gas.
any ideas? i will likely just take it in and have the codes ran if i cannot track down the culprit. My WJ has been reliable for the past 5yrs with no issues so im at a loss as to what it could be.
Thanks in advance!
Sean
Fully charge the battery, 8 hours or 24 hours (best).
While charging the battery take the time to clean all of your battery cables, both ends, and freshen the other system grounds.
After the battery is fully charged, take it and have a load test done.
