joe_peters
- Grants Pass, OryGun
crank
For what its worth, on the Renix the Tach reads from the negative side of the ignition coil, per 1990 FSM.
crank
That may be, but we are talking about a 99 which does not have a separate ignition module. Also he was looking at a scan tool and seeing rpm's. Not to mention when my crank sensor kicked the bucket on my 95 I had no tach reading at my gauges or on the DRB.
so when should i have power at those 2 fuses? ive been going through wiring diagrams trying to make sure the ASD relay circuit is fine. I have no power at fuse 21 or fuse 24.
edit: i have power at both fuses when cranking. is this normal?
