33's on 3.5" lift?
http://www.naxja.org/forum/search.php?searchid=99729
It takes a combination of trimming and bumpstops, and depends on the backspacing of the rim, and whether you're talking 33x12.50's, 33x10.50's, 285's (33x11.5 on 16-inch rim), etc. More of one = less of the other when it comes to trimming and bumpstops.
Trying to think of the easiest answer to give you, and all I can come up with is cut as far as you can in the back without cutting the pinch seam and bend the edge over. In the front, cut as far as you're willing to, the farther the better, but make sure you like the way it looks. When you're done cutting, throw the tires on there, flex it up, and add bumpstops accordingly.
ive got 31's on a 3 inch lift and ive scraped hard enough to dent the fender, but i do need some new bump stops so i would recommend 31s
