jeepnfahey
- poland Maine
Will 31's fit with a 2 inch lift? Will i have to do some fender trimming? How much? does any in have 31's?
1. got search?jeepnfahey said:Will 31's fit with a 2 inch lift? Will i have to do some fender trimming? How much? does any in have 31's?
A little? You must have not flexed the front too much then. I had 3.5" and I rubbed a LOT with a fair amount of trimming. Then I trimmed it more and put TJ flares up front: metal shears, sawzall, grinder rockJeffro600 said:31's will fit with a 2" lift, but you will probably rub a little bit unless you do some fender trimming. I had 31s with a 2" OME lift and some mild fender trimming and the only place i rubbed was the lower control arm at a full left hand turn...but that was due to rim backspacing...not the lift.
Kejtar said:A little? You must have not flexed the front too much then. I had 3.5" and I rubbed a LOT with a fair amount of trimming. Then I trimmed it more and put TJ flares up front: metal shears, sawzall, grinder rock
