Possible - yes. Easy - no. You need to bore from 3.875" to 4.000" (+.125") and install a crankshaft that has been offset ground to 4.000" (a 4.060" is available) - which will also require clearance work on the oil pan rails.
However, going to the 4.5/4.6 or so stroker is easily done with a regular bore (or close to it) and the 258 crankshaft...)
5-90
