I have 2 D30 front axles both have a tag stating 3.55 ratio. The axle I'm pulling (factory axle) has a 46 tooth ring gear and 13 tooth pinion.... 46/13 = 3.538 ratio.
The axle I'm going to use to replace the factory axle has a 39 tooth ring gear and 11 tooth pinion..... 39/11 = 3.545.
First time I have run across this issue... Anyone have any experience with this?
