2xtreme
- Kayak Pt, WA
jeepinxj99 said:hey i called down to rubicon express and the guy said that you could go 6 months without getting an sye. i assume he means you just have to put up with the vibes. Thats for a 3.5 by the way
RE makes some decent products but I have yet to find anyone or hear of anyone who knows anything about xj's there. Time has nothing to do with needing a SYE.
If you lift it (and properly set up shims) and have No or almost No vibes great you are set. If that does not work, then add a transfercase drop and re-shim. If that still does not work, the SYE is the only thing that will do it for ya (shimming again of course). On a newer XJ, I would plan on the SYE, you may very well not Need it.
Any vibration does hurt driveline u-joint wear. The more the vibe the worse the wear, the less the vibe the less the additional wear.
You can get as frustrated as you want searching, but many people stop posting info on over asked questions because we do not want to spend the time to type the answer over and over again. The better you are at searching the quicker you can find info on what you need.
Michael
