clunk
- West Kootenays, BC (canada)
My 2000 XJ has the NV3550 5spd and 3.07 axle gears. I need to upgrade the tires in a few months and would like to run a LT235/75/15 tire with a 2" budget boost. I also have a set of all terrains that measure 30x10.5 which I could use in the interim, thus saving me the cost of buying new tires until these wear out.
The difference between the 235/75/15's and the 30x10.5's that I have now is around an inch in both width and height. I'm ready to accept some performance loss from larger tires but will the 235/75/15 really be that much better than the 30x10.5's with my gearing? My engine is strong at only 105k and the NV3550 has a lower 1st gear than the AX-15 so starting might not be as bad, but maybe this is just wishful thinking.
My engine pulls well in every gear with the stock 225/75/15's but 5th is not used much on the long mountain passes around here so I end up winding 2500RPM in 4th. By my calculations the bigger tires would drop RPM's a little and might actually make 4th gear up hills more enjoyable (right now I can watch my gas gauge drop in that RPM range).
Any comments or opinions? The long term plan is to run a 235/75/15 tire like a Duratrac - I've found to be this size ideal for all my DD jeeps. Is there going to be much of a difference between the two tire sizes with my gearing?
This is what the tires look like next to the stock 225/75/15
