2wd WJ knuckles on a 4wd XJ?!
Pnwxj808
Port orchard WA
Is the 2wd knuckles on a 1999 WJ the same as the 4x4? I have a WJ that I want to swap the brakes and rotors to the xj is that possible or do I need a 4wd WJ?
Yes, they are the same. I pulled two sets from a PNP yard, one from a 2wd, and one from a 4wd. Both were exactly the same when I compared them. Both had the same casting numbers on them.
They are but you want to newer akebono calipers.
