Hudson Bend
- Austin, Texas
I knew that comment would get me ragged but hear me out. Your weights to one side and the opposite side is spinning freely in the mud, just how much of your engine's torque is getting to the traction wheels? 10%? Less? Unless you've got both wheels down and grabbing similarly your open diff works at a fraction of its potential whereas a locked rear would give you closer to 100% of available power. Offroad how often do you lose traction in front and/or rear wheels cantilevered, in mud or over rocks. Why is it that you lock your diffs as soon as you can?
The OP is young and may or may not be a super mechanic. What are the odds? Whatever, my advice was tendered based upon things he could do to improve the existing performance of the existing machine...things he could do if he were a normal high school kid in a world without automotive classes. He can mod his suspension for larger tires, he can improve his off roading with a rear locker. Doesn't hurt, does it? If he manages to pull off the front end d30, will he want to take the locker out?
is a worthwhile forum but at times exhibits steroidial type tirades if a comment isn't up to body builders level of mechanical fitness. I have my opinion, and you have yours. I based mine on the OP being in high school and living in NC. I based mine on knowing several damn good(at times) offroaders using locked 2wd units and having a blast without succumbing to such a narrow minded view of off roading. And for me, this is real.
