bwinter1946
- Madera, California
FYI, the Tom Woods machined shaft is a stock shaft that is machined but it is not fair to call it a hack and tap IMHO. The TW shaft is shorter than a do it yourself hack and tap. He machines the splines further up the shaft than the shaft originally came with. That gives you a shorter output shaft which gives you a better angle to the rear end. In addition, the output bearing is closer to the output yoke for better support.
See the attached PIC for comparison
