check rough country or some place like that, they have shackles with multiple holes for different lift heights, and they are usually cheap,
that will allow you to ditch the blocks..
now look at your pinion angle and shim accordingly
then get rid of the tcase dop, if ya cant get an SYE setup, then you can run a drop if ya need but limit the drop to as little of a drop as possible....
