jeeptec
- atascadero california
231 tfc parts out of TJ with manual trans. Has tera flex 4.1 low gear kit. Planetary gear has one set of pinion rollers failed. transfer case is repairable. I called tera flex for $450.00 you send them the front case and planetary they send you a new planetary and new ring gear pressed into the case.im including the front case and planetary, chain front output shaft. Shift rail, forks and main gear for chain. Back housing. Sorry no output shaft or tail housing. I'm asking 200 or trade for lift kit parts for an XJ. I need 3 or 4 inch front springs. Rear extended shackles. Front bar pin eliminators.. etc. Eric
