ok, they do mention the 231 w/ d300 combo, but they also mention this could be done w/ 2 231's.
So, I was thinking, pick up another 231, then the kit.
I have an 89' stock 4.0L, A/T. D30, 8 1/4. My thought was throw in some 4:56's and the doubler with 35's and I would have a decent all around combo for what ever I encounter on the east coast.. I would have the stock 4LO for the usual, then the 4LO-LO for rocks. Seemed like a good deal to me, wanted to know if anyone else had the idea or had done it, or better yet knew the problems with it..
I thought the $599 for the kit was a bit steep though...
After reading the post pirate I been seriously thinking about, but I don't want to get to the expense of what altas would cost or I would go that route.
Like I said, check the input torque for the second 231. With a standard XJ manual, you'd be at 2439 ft lbs with a stock 4.0 (225 ft lbs). Maybe a touch more with an auto, but it's got a converter to soak up shock loads. 2439 is far above the rated torque for a 231J. You would have to retrofit the 241 or 231C parts to get your input torque rating up a bit.
CRASH, I also read the Pirate thread and it interested me. What would be the downside of a 231/300 combo, other than the redicules $600 price tag for their adaptor?
Assuming I could machine the adaptor plate myself, wouldn't that give me a reasonably bulletproof low range TC for about $1500 less than an Atlas?
Not sure of the torque rating of the 300, but with an upgraded output shaft on the 300, I think it would be OK. The 300 has proven itself over the years behind V-8 power and low geared manuals.
I guess if you could make the adaptor and the flip kit yourself, it would be a good option to run a 300 behind the 231. You'd at least be eliminating the slop of the second planetary set that you'd have with the 231. For the average Joe, however, adding the flip kit to a rebuilt 300, and then the 231 doubler adaptor puts you easily in the range of an Atlas $$$ wise, especially since the price is going to come down when the 4 speed Atlas comes out in January.
This would be a worthwhile upgrade if you already have the 231 and the 300...whats an altas cost...2000+?? I dont know what you guys do for a living, but i dont have that kinda cash to throw into a trasnfer case...granted, its not an atlas, but it seems like a decent, much more inexpensive alternative if you looking for a lower crawl ratio. If i can find a 300 for cheap, i might look into the kit some more.
High Angle Driveline has the Stak for sale for less than a similarly equipped 4.3 or 5.0 Atlas.
Advanced Adapters has a 4 speed Atlas due out soon, but it's a plantetary reduction in front of a geared case, essentially a Klune in front of an Atlas but in smaller packaging.
FWIW, I've seen as low as 1.7-1.8 quoted for the AW4 converter. Internet lore and all but it makes for more optimistic calcs. I always use 2.5 regardless of which make transmission. I have an old Hummer H1 brochure (Civie) around here and it quotes 2.2 for the 4L60E (or was it 4L80 - can't find it currently).
as far as that Stak case.. for the price I would go Atlas, dont they have a 3 spd coming out?
If you were in my neck of the woods I'd agree with this but if you are doing south west style rocks I think this may be a touch of false economy. (FWIW)
I dunno about those torque numbers, I mean I know the math is right but the only time you are ever going to see that is if your tire is wedged under a rock, not turning and you give it all the power you can. And if thats the case I don't know of much that would hold up.
