danny Benavidez
- Texas
No, the engine will crank, run for a second or two then cut off. The system is not recognizing the key as indicated by the flashing no key light.
X1
Yes the jeep will start and run with a bad key for about 2 second or if I hit the gas about 20 feet.
There is a fuse for the sercurity key. --> Replace It <--
If the No key light is blinking in the dash. Than you got a security key problem.
