2000 XJ part out, lots of goodies!
Darn, cant believe no one bought this thing as a whole. Thought you were asking a very reasonable price. Good luck on the part out.
**Updated List**
***Updated List***
35" Goodyear MTr Kevlar, worn evenly, great tread left, on Soft 8 rims, brand new spare, balanced with airsoft beads, great ride for 35's! Tread measurements are as follows, 14-12-12-12/32nds, the new spare measures 21/32nds and still has the sticker on it-$850
First gen. Wilderness Roof rack, includes highlift mount, spare tire mount, rack for shovel/axe and the eyehooks on the front for the 4 spotlights, crossbar on rear drilled for 2 backup lights- $250
tan leather seat from older xj, really good shape, 2 front and full rear seat, patched tear on passenger seat, mounted on manual sliders- $125
OBA setup, includes 3gal tank, manifold, a/c compressor and all the lines, very well setup, the tank and manifold mount in the rear cargo area, air line and chuck for tires included, fills all 4 35's in a matter of minutes and will run a 1/2" snapon air gun to take off pinion nuts with ease!- $200
4 KC Daylighters, 2 backup lights, 100w on the daylighters, 55w on the reverse lights, decent shape, one of the daylighters needs a bulb. Includes plastic covers and KC soft covers- $125
JKS trackbar, the home brew one, NEVER driven on, will be sanded and painted before sale; has rebuildable ball joints and comes with RE track bar bracket- $150
Home brew hand throttle -$50
60" Highlift jack, needs some lube but still good working order -$50
3 stock front driveshafts, 2 with rebuilt cardans, $35 each
231 TC with stock tailshaft- $100
Tan center console, comes with painted black bracket on pass. side for GPS mount- $30
Tan lighted visors- $30
ZJ shift knob- $10
HD battery shutoff switch, Painted bracket, mounts right behind battery, all cables included VERY HEAVY DUTY, 230amp switch- $80
Black rear doors, power windows locks, great shape, with the exception of a dent in the passenger rear door, tinted rear glass, all options work, complete door assy's- $50/door
rear hatch, black, small dent on drivers side, inside platic panel needs a couple tree pins to hold in place- $65
2" Poly Budget spring spacers- $20
OEM steering box, good shape, no leaks- $50
Durango HD steering box, good shape no leaks- $65
Inline 6 coil pack, good shape- $60
6 Spidertrax 1.25" wheel spacers, $75 per 2 spacer
Trailhead Tire Deflator set, comes with 4 deflators, allen key, PSI gauge, manual and quick reference sheet for tire psi's, 5-20psi range adjustability, used 3 times. $50
Cherokee shell, very little rust, some dents and dings and scratches, rockers and rear quarters dent up, in sheet metal, "Frame-rails" are in great shape, comes with AW4 trans attached!- $200
Most interior panels, mirrors, interior lights, engine, tranny, outside front end lights, and anything in the engine bay available, pm for pricing...
How much for the washer bottle, motors, and everything else in there (I can't remember what all it there, ripped it out a long time ago) shipped to 07302?
