USMC1371WJ
- Bridgeport, OH
I have a 2000 WJ 4.0 and just pull the ring gear out of the front end BC I need to replace the axle seals as well as the side carrier bearings, my question is, after I pulled the gear out it is stamped 48386 and when I was cross referencing it said that this ring gear is a 2000 Jeep liberty . ?? And the WJ part number on the reference page was completely different than the one I just pulled. 1st off did not know these were interchangeable between the grand Cherokee and the liberty.. reason for all of this was BC after a fluid change I started to get a binding /squealing come from the front end, mind you the CV axles are brand new as well as the hub assembly/wheel bearings.. any help on what to do or what the cause of this noise is would greatly be appreciated, it only does it once it is warmed up..
