2000 Parts
5.9longarmXJ
Jacksonville, FL
Now that I have pretty much finished my engine swap, I have a lot of parts available. I would rather offer them up here to members. If you see something you need, make me an offer (jeep had 145K on it when I pulled everything)
Engine and transmission with intake with throttle body and exhaust header (california emissions) (water pump new)
Alternator
A/C compressor
Exhaust downpipe (Not whole, cut after the pre cats, but the pipe is the easy part, its the cats that people need) again ca emissions
Catalytic Converter
Power steering pump (reservoir cracked, but pump good)
Kind of, I did cut into it. With the 5.9 magnum swap I did, I needed the VSS wires that run to the transfer case. So I cut out the connector that runs to the transfer case. I think It has wires that run to the trans as well. If you are interested, I can look at it and give you all the details.
Still have parts available:
Alternator
A/C compressor
Catalytic Converter
PCM
TCM
Electric Fan
Rubicon Express Drop Bracket Braces (only the braces)
Willing to ship certain items. Make me a fair offer.
interested in the transmission -looks like it will bolt right up to my 98 . 145K is Low miles- did it leak? super interested. you are basically south of fresno , near visalia? Like I really want this transmission if we can work out a deal.
PM sent.
