Sidewinder CC
- Canton, Michigan
according to my a/c guy, my high/low pressure switches are working fine. Its the fact my system is building too much pressure in the first place thats the problem. It shouldnt be climbing to 300+psi at idle.
You should find out what the exact pressures are.
See pressure problems trouble shooting below.
1. Condition:
The low side pressure is normal or slightly high, and the high side pressure is too high.
Possible Causes:
1. Condenser air flow restricted.
2. Inoperative cooling fan.
3. Refrigerant system overcharged.
4. Air in the refrigerant system.
5. Engine overheating.
2. Condition:
The low side pressure is too high, and the high side pressure is too low.
Possible Causes:
1. Accessory drive belt slipping.
2. Fixed orifice tube not installed (unlikely)
3. Faulty compressor.
3. Condition:
The low side pressure is too low, and the high side pressure is too high.
Possible Causes:
1. Restricted refrigerant flow through the refrigerant lines.
2. Restricted refrigerant flow through the fixed orifice tube.
3. Restricted refrigerant flow through the condenser
