1999 jeep cherokee, aw4 transmission problem.
sjordanxj
Lakewood, co
So long story short i bought a '99 cherokee that I was told had a cracked valve body. The price was right so i jumped at it. I never did drive the cherokee before having it brought to my house, but was told it would move on it's own on a flat surface but it would not move going up an incline.
I have looked all over the valve body and can't find the 'crack' has anyone dealt with a cracked valve body on an aw4. Would it be a noticeablecrack to affect performance?
To compound the issue I live in St. Thomas, USVI. parts availability are slim at best (going to the pull n' save yard and getting a used transmission isn't an option)
I can see some the edges of the clutch packs, and there is play in them when i wiggle them side to side- is this normal?
Thanks!
Seth
Use the Google, and find the AW-4 Service and Diagnostics Manual. Perform the tests and follow the diagnostic charts.
Until you determine what is actually wrong, all anybody can do is guess as to the cure.
