jimmydaux
- Centerville, Utah
Good morning gals and gents.
I need your opinion and am completely aware that I will catch some grief for this little situation.
I have a 98 xj that had the c 8.25 axle that I had been running swapped Grand cherokee disc brakes. I have since purchased a set of axles (D30 and C8.25) that had 4.56 gears. Once that set was installed, I discovered that the 8.25 rear end needed to be rebuilt. I pulled that axle to do a rebuild, and purchased a lockrite adorned early 90's dana 35 with 456 gears to get me by until I can complete the rebuild on the 8.25. This Dana 35 axle has equal length ebrake cables that are obviously not compatible with the 98 style offset ebrake cable box on the undercarriage.
So, here is where your advice comes in. My long term goal is to get my 8.25 back under my rig, but I need to figure out a way to get my ebrakes hooked up in the interim.
SHould I:
A) Try to swap my Discs from the aluminum housing dana 44 from a grand cherokee onto the Dana 35 (currently on the c8.25 and I have e brake cables that work with my rig)
B) Buy and swap different length ebrake cables that will allow me to use the current location of the ebrake cable box on the underside of my rig.
C) Relocate and modify the ebrake cable box to a central location and add cable spacers so that I can use the existing Dana 30 Ebrake cables?
I am looking for the cheapest, quickest and most simple solution to get my ebrake to be at least somewhat funcional, as I need to get this thing through a safety inspection.
Your insight, expertise and problem solving skills will be greatly appreciated. THank you in advance
SHould I:
