A Satria
- Jakarta, INDONESIA
Just a thought...
8" shocks travel :
At the moment XJ is already lowered
Exposed shock shaft for compression to full axle to bum stop is only 3" (front/rear)
I Still have 5" of shock shaft for droop
Pros- I will be able to fabricate the mounting as an standard factory look.
Cons - Less compression and DROOP !!
10" shocks travel :
When the car is put back into Original height, it will have 50/50 compression to droop (5 inch)
I will have 5" of shock shaft for compression and 5" shock shaft for droop
Pros- I will NOT be able to fabricate the mounting as an standard factory look.
Cons - Lots compression and DROOP !!
Questions ::confused1 :confused1 :confused1
8" shocks travel :
10" shocks travel :
- Can you use 15x29" inch tires or 30" inch tires on standard XJ ?
- On standard XJ height using 29 or 30 tires, will you be able to do moderate adventure trail without rubbing the tires to the fender or anything else ?
- Should I use the 10" and re-do all of the shocks mounting, or just leave it as it is with the 8" inch coil over ?
