1997 F250 4x4 5speed Extended cab Long Bed
iluv83vettes
Houston
Truck has 253K on it. Transmission was rebuilt at 225K, only case is original on it.
Mods include:
Intake
4" exhaust, 5" tip, with muffler
boost and pyro gauges
put some international parts (t-stat, fuel pressure regulator, High pressure oil equalizer) on the motor to make it run at their specs instead of ford's spec. Now is smoother and gets a little better mileage.
PHP 6 position chip with stock, 60 hp, 80 hp, 140 hp, high-idle, and no start.
I usually leave it in 140 hp and keep my foot out of it and it gets the best mileage (18 city - 21 hwy, 15 towing my old jeep (avatar pic) on 20' low boy)
I completely removed the interior to put sound deadening material in and a full sound system. The decibel meter app on my phone said it was ~85-90 db before and now its ~60-65 on the highway with the radio off. The sound system was built to sound clean and not be overpowering.
I can email more pictures if you would like
[email protected]
281-435-5607 call or text. If you call I won't answer because I am tired of answering "Rachel from cardholder services", but if you leave a message I will call you back ASAP.
Looking for $8,000.
I wouldn't hesitate to hook up to a trailer and haul something to the other side of the country.
I don't know why the last picture is upside down ... I promise the engine is actually mounted correctly in the truck.
No one needs a tow rig?
