- MilkyWay Galaxy
Depends on what other loads you strap on that alternator too? But by itself it might be OK. A good working fan clutch saves horsepower!!!! Keep that in mind.
Your problem is a classic bad fan clutch!!! If a new fan clutch does not solve the problem, an E-fan MOD would not solve it either.
A new fan clutch is only about $35. If you get the ZJ HD fan clutch they are tougher, and lock up sooner and turn the blade about 20% faster!!! I have Renix rigs with both the OEM and the ZJ (Grand Cherokee 4.0) fan clutch. Both work. I get a little better AC cooling at idle with the ZJ clutch.
So change the fan clutch. Then if it still overheats it is either the radiator needing cleaning or replacement or an exhaust leak blowing on the engine block. My last problem was a bad flange donut leaking exhaust on the block <1 " away from the block, and it even passed a muffler shop inspection!!!!
