1990 xj built
joshfj40
grandjunction
located in grand junction CO
1990 jeep Cherokee dropped to $4500
I have decided to go with a much milder vehicle. It goes 65 down the highway fine and does great in the rocks.
short block is low mileage HO but the top is all renix still
brown dog motor mounts
aw4 automatic transmission
¾ ton ford high pinion d44 front with zip locker RCV shafts and high steer 4.88 gears 6 lug
full width 8.8 rear welded with Dutchman shafts and disk brakes 4.88 gears 6 lug
long arm front suspension not sure how much lift
4 link rear with coils and BBC shocks through the floor
prothane coil spring inserts for bumpstops
full cage
suspension seats in front with harness
half doors up front with snap on windows. also have a set of stock doors
superwinch hidden behind front bumper
36inch IROKS with a lot of tread still
radio works most of the time but sound cuts every once in a while
8.8 whines like most
could use some new bushings up front
