1990 Cherokee Limited in W. Mass
KaiserMan
Huntington MA
1990 Cherokee Limited 4-door. 160K 4.0/AW4/NP242 D30 (non CAD with large u-joints)/Dana 30 (non c-clip with Trac-Loc) 3:54 gears. 162K miles iirc. It's my daily driver. Only selling it becasue I just bought a full size Wagoneer can't have both.
1 3/4" lift (spacers) up front, 2 1/4" lift (AAL/Zero rate AAL) rear.
Met. Blue w/Charcol leather interior. Over head consol, custom rock sliders, late model headliner w/rear speakers, NOS AMC/Jeep rear tire carrier, Marchell fog lamps, bolt on push bumper. Lund visor, rear air deflector
PS
PB
PW
hatch and RF PL (others move a bit, but are gummed up and a cleaning should have them working)
P-mirrors
rear defroster
Clock
Thermometer
Privacy glass
rear wiper/washer
cruise (needs multifuction switch to work-priced it out at $80 from Napa)
tilt
P-seats (all but one function on the drivers seat work)
ABS (does not work, but does not effect braking, just makes a noise when pedal is depressed)
CUP HOLDERS!
AMC AM/FM CB (might not go with it)
P-Antenna (pulled the fuse, gears are stripped)
rear heat
A/C (needs either freon or low temp sensor, compressor and clutch seem to be good, and nothing is open).
Probably more. It's LOADED.
30x9.5 BFG A/T on stock 10 spoke turbines
Comes with 5 stock 15x6 steel wheels for winter use.
New within 5K miles
3-Peice Renix Vac. Harness
All four shocks
Heater control valve
Water pump
Serp. belt
Valve cover gasket
fan clutch
1 Tie rod end
Muffler
tailpipe
New withing 1.5K or less miles
Windshield
All four ball joints
Both axle shaft u-joints
Both rear shaft u-joints
T-stat
T-stat housing
Elec. fan switch (in radiator)
Rotors
Pads
LF caliper
NAPA Ecklen(SP)/Beldan plug wires, cap, rotor and Delco(IIRC) plugs
Anti-freeze (flushed heater core at same time, heat works great)
Rear brake shoes, hardware and adjuster kits.
Have much orginal paper work, including window sticker with MSRP of $27K
Minor rot, nothing major. Only spot on body is 1/2 dollar sized spot on RR quarter. Some surface rust.
I have zero problems with the Jeep. Runs, drive and stops great. Gets around 15-16MPG.
Asking $1400 b/o for it. The tires on it now aren't going with it. I have picked up a squeal in the LF brake that I can't seem to get rid of in the past couple of weeks, might be in the pad?
Best way to get a hold of me is to email me at: [email protected]
